Gas check maker -- need help please.
nhrifle
Jun 28, 2013
4
I am in the process of making a gas check maker. The main forming/punching die is an old Lee bullet sizing die that has been repurposed for the project. I have bored it out to the necessary sizes and have the disc punching rod turned. I cut the slots in the die to feed the strips of raw material through to punch the discs from, but I need to widen them internally without removing any external metal. The die is hard enough that a file just skips over it and a hacksaw just polishes it. Any ideas for a small abrasive cutter to open the slots inside the die without affecting the outside would be appreciated. My Dremel wheel and arbor were used to cut the slots initially.
Can you get a diamond disc in there? There are diamond covered cutoff disc available. Or use diamond burrs.
Pierre
