Have removed the cross slide from my lathe and the shaft from the hand wheel to acme screw is a 10 tooth pattern extremely worn. I've looked at involute gear cutters but the largest, #8, specs for 12-13 splines. Have looked long enough to be thoroughly confused so hoping someone can shed some light?
