Gear Hobbing
I have been looking at this kit.
Pierre
I'm actually about 90% done with that kit! Down to the last 90% :D
Thanks for posting Bob
I use the same method to cut small gears with great success. Just thought I'd point out, when you reduce the ends of the hob? to clear larger diameter gears, there should be cutters out there to in-fact remove that material from the gear blank. Though small, that corner you'd be removing will bring you closer to the proper tooth form.
Greg
You're exactly right. I never thought about that before.
The gears I've made have seem to work and mesh pretty well. But you're right I'm potentially missing a little bit of a proper cut.
Thanks for pointing it out.
I assume he advanced the blank by one tooth for each cut. The ”hobb” (using the term loosely) probably contacted the work piece with 3 maybe 5 cutter teeth. When he rotates the blank one tooth, those teeth that were partially cut will get an additional cut. Let’s assume each tooth is impacted by 3 steps (blank rotations). What you end up with is a piece wise linear approximation of an involute. Granted it’s a crude approximation, but I believe you can improve the accuracy by lowering the cutting tool a small amount, and rotating the blank an amount equal to the amount you dropped the tool. Now cut all teeth with this new position, and you will knock the high spots off the linearly approximated involute from the first pass. You can do this a number of times and get a progressively better curve instead of the crude first pass tooth profile.
This technique uses the same simple setup and “Hobb”, but with a slight tweak in setup and a lot more time, you should be able to produce a nice tooth profile.
Obviously the best approach is to use a Hobb cut on a helix, and have the blank driven in sync with the Hobb, but that setup is non trivial. BTW… I’m looking into designing exactly this which is why I’m looking at what others have done.
I'm interested in gear hobbing. Anyone built a gear hobbing machine.
I have. I started with a rescue mill that was missing a lot of parts, but still had the spindle and a swivel table. By the time it was finished I could hob +/-45 deg and all tooth counts, including prime numbers. I tried digital division, but results were not ok. This machine is all mechanical…no zeroes and ones. I have a YouTube channel, if you want to see more..IMG_8909.jpegIMG_8910.jpeg
Wow. Quite the machine. Post a link to your channel. I would love to see this in operation!
Not sure I’m allowed to post a link yet, but you can search for Tom’s Rabbit Hole & gears or YouTube @thomasstover6272
I subscribe to your channel and really like your approach to getting things done!
I have. I started with a rescue mill that was missing a lot of parts, but still had the spindle and a swivel table. By the time it was finished I could hob +/-45 deg and all tooth counts, including prime numbers. I tried digital division, but results were not ok. This machine is all mechanical…no zeroes and ones. I have a YouTube channel, if you want to see more..View attachment 491511View attachment 491510
Beautiful
