- Feb 8, 2021
- 13
So i tried cutting a 20 tpi part today. I ended up with 23 or 24 threads per inch. So if i understand correctly the bull gear should be 24 tooth unless doing course threads. after reading through the manual i am a bit confused as to which gear is the "bull" gear. Obviously there is something wrong here, but i am not sure what exactly or if it is multiple problems. I do have what i believe to be a full set of change gears. Would anyone be so kind as to walk me through fixing this?
Logan ward15tlc-2130 lathe, 74tlc-2138 qcgb. 10" swing.
