- Jul 11, 2020
- 47
Hi I am attempting to tidy up a Light 10K that I just purchased and in doing so I noticed something which I think is not right. The left hand side gear lever wont go into the top middle hole, it will only sit just to the right of the hole. Looking inside the gearbox it cant go any further left because it hits a gear.
Just so you know, I am a total newbie at this, I have barely turned a lathe in my life let alone a south bend so I dont even know if it is supposed to go into the top middle hole!! But it does on the newer gearbox.
Now this lathe came with another (unused) gearbox, so that tells me that the old owner must have been having an issue. However it was suggested the new gearbox my be for a 9 inch. But when I look at the cogs they look almost identical to me. Sure the new gearbox has a couple of extra cogs but they appear to be attached to the same single cog the old gearbox has, it looks like a slightly stronger design.....same size cogs just a double row of them for strength perhaps?
Can someone who knows a lot more about this than me have a look at the pics and tell me if it will work on my 10k.
Just for the record if it helps, the old gearbox's catalogue number is CL670A and the new gearbox is CL644R.
Is there someone I can email to get a definite answer if these are interchangeable?
Thanks very much for any help.
