The double key way gears from Boston Gear are standard "pick" gears or "change gears" they used to sell. They made special bushings that were double keyed so you could compound gears together for special gearing for many types of machines, just not for only lathes. Mainly for gear cutting machines, thread milling machines, and of course, lathes. I seen special machines setup cutting spirals using change gears. This has all gone away, to the use of electronics now days.
