I know this subject has been beaten to death, but still after reading (and watching) everything I can find few questions remain for me.
I have no problem setting gibs by feel for tables and cross feeds, but I have a large-ish (just under 2 tons - 4000 pounds) knee type rectangular/box way milling machine I'm having difficulty setting gib clearance on. The machine is not a popular type (an east German Heckert FW250) so I'm making my question generic.
The questions are:
1. what is the correct clearance (the manual doesn't specify it, it only says how to increase /decrease it).
2. what method is used to determine it in detail.
3. Should there be knots/pieces of string in ways oiling holes under gibs?
I found a bunch of answers to 1 with the consensus being somewhere in the region of 1 thou, but methods of measuring it vary. The wear of the ways on this machine is a bit under a thou.
Someone said they just put a dial indicator on the column and reversing hand cranked movement direction shows them the clearance. This doesn't work on my machine. The dial indicator stays still (I'm using a 1um indicator, similar to tenths in English units).
Then there is the rocking method, essentially you grab a hold of it and you push-pull with all your strength. This indeed shows movement and I thought I was doing it correctly until I saw a youtube video where it was mentioned at the correct gib setting when you release your pulling/pushing the indicator should settle in the middle.
That's not how it works for me.
Finally the oiling. The machine has an oiling system where when a valve is pushed oil is sent to all way oiling holes connected to each other so it will go the path of least resistance(which is usually the column as the oiling hole is located the lowest). If the valve is held long enough oil eventually reaches the table, but upon release it slowly drains all the way down again. Perhaps if there was felt or string in those holes it woukd prevent it? On the other hand I don't want any material being pushed into the space between the gib and the casting. This sounds like a recipe for a jammed way. Again the manual is useless in this regard :-(
The questions are:
