[4]
Grinding an ER40 Taper
[3]
[10] Like what you see?
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
1,919
I thought I'd try out my tool post grinder I made last summer as I've never used it.
I bought an MT5-ER40 collet chuck that is showing almost .003"TIR so thought I'd try to grind it in.
My question is, does my indicator have to be perfectly on center to align the compound w/the ER taper?
benmychree
John York
Jun 7, 2013
2,858
Yes, it does, and you may have to do come "cut and try" using layout dye or felt pen inside the hole to see if the taper matches, and the grinding spindle needs to be accurately on center also or the taper will be distorted into a convex shape.
T Bredehoft
Dec 27, 2014
2,833
Absolutely. .005 off will make a bad taper, either bell mouthed, or fat in the middle.
[6]
[5] [7]
