- May 26, 2015
- 815
Finally got around to checking the run out on my Craftsman 101 small 4" 3-jaw chuck. My chuck run out was .006" and knew I had to grind the jaws. The thru hole is so small I had to come up with a way to pull the jaws tight enough to be able to get my pencil grinder in the hole. I used safety wire pulling the jaw as tight as possible so there was no play. After grinding my jaws the run out is now less than .001". I am cutting some large 3/4"X 9" door hinge pins and there is .003"to .005" difference between chuck and live center. There is no noticeable play in my live center and doing a left hand cut. I've gotta find a cross slide follower for the long things on my little lathe.
