Hello all. I'm looking for some guidance/advice. I have a 618 that is about ready for reassembly and figure I may as well get the bed ground while it's apart. I do not yet have the tooling to indicate and inspect the bed, so won't be able to answer your questions on the current condition. I figured the machine shop would handle that. There is only one shop in town with a grinder large enough for the job. They are not a job shop but said they could accommodate me, which is great but this is where things got confusing for me. I assumed a machine shop equipped with a grinder that size would know exactly what was involved with grinding a lathe. When I presented the base, he looked a little confused. He asked how much I wanted removed? I said the minimum amount to make the ways true and parallel to each other on both axis? Then he asked about the sides and if I wanted them 90° to the bed, because that will be an issue...
I didn't know what to say. I wasn't expecting this.
I don't think the guy is a traditional machinist. The shop is full of wire machines and a few 5 axis HASS machines. The shop turns out extrusion dies and I think this guy is more of a program and run sort. I don't know. Sorry for the lengthy story and he are my questions I hope to gain clarity on.
1. Should I risk moving forward with guy even if he can't grind the vertical sides?
A. If yes, could the bottom of the bed just be stoned, mag chucked and fed to the grinder and shimmed on assembly?
2. Could this be done with a typical 18" grinder, by the right person? (Lathe bed is 30" overall)
A. Would it be worth the trouble/cost?
3. Should I just leave it alone and focus on other aspects of learning the machine?
4. My experience is =/< zero. What am I'm not considering?
Thanks in advance.
M. Noob
Thanks in advance.
M. Noob
