Grinders like this are mostly made for sharpening engraving type cutters, and looks to be capable of grinding an end radius, and sharpening the ends only of end mills; it does not appear to have a sliding quill, so would not be able to grind the flutes of end mills. If you want to sharpen engraving cutters, this is the machine for you, but if it was up to me, I'd look for an older US built machine, like the Gorton #500, or #375, which can grind flutes of end mills. and are much more finely built, which, for the most part, the asian built ones are not.
