http://www.grizzly.com/products/7-Piece-Indexable-Carbide-Set-5-8-/T10295
This set is vague about the inserts it uses. Grizzly sells sets of 7 assorted inserts but doesn't specify the grade of insert. Also, I'd prefer more of some, fewer of others because some of the tools get used a lot more than others, so buying an equal amount of each I'd have too many of some & not enough of another.
Typically their documentation is pretty good but not on these, so I'm unsure of what inserts to buy for this set. Specifically these 2 tools:
RH Threading (LW with JCL insert) - RH Threading tool, LW holder, JCL insert Cut-off/Grooving (QA with JCQ Insert) - Cut-off/Grooving tool, QA holder, JCQ insert
No idea what a JCL or JCQ insert is. Any help or direction where to find those inserts would be appreciated.
I turn 6061, 7075, 4140, 303, 304, 416, & 6AL4V. I found (by trial & error) which inserts work well for some other indexable tooling I have for the different materials & will need to do the same for these. The CCMT size is common to what I already have so I'm good there, but for the others I'll need to find what works best.
