- Jun 26, 2018
- 1,733
FWIW, I made that "Hemingway" broach. Their broach is pretty small, so I scaled up their drawings and made a tool capable of making much larger squares and hex's. I got permission from the Hemingway guys to share the drawings. Let me know if interested.There is a British company that makes these and everyone copies those...I'll see if I can't find those plans or instructions, something.
In the other two group projects everyone buys the materials for the parts they are making. The boring bar holders are dependent on the size of the tool holders (mine are 1.250 with a 1" sleeve), but I'm up for whatever size the group is.Shank diameter. a 3/4" boring bar holder could be used to hold it in an Aloris type tool mount. Or, half inch with a sleeve.
Where does material come from? I'm considering joining the project.
I think this design is just grease The face of the 'broach holder' and the 'body' are the bearing surface it seems.Questions....lots of dimensions missing....what provision is made for thrust bearing surfaces? or is that the "grease"?
I've seen a couple withe the ball-bearing in the middle, I'm definitely up for whatever designs we come up with. That design above was just the one I found in my machining folder.I was wondering the same thing, however, if you have seen the AVE guy on Youtube, it did it with two divits (one off center) in a couple of pieces f steel...with a ball bearing sandwiched between the two. It's a crazy simple device, but yeah, if we could find plans that made a higher level tool, that's awesome.
This is a pretty nice one! I'd almost definitely make the tool 1/2" and scale it up for a 1/2" bit simply so we can use commercial broaches though.
Here is a photo of the Hemingway broach holder and its scaled-up companion. Both use 1/2" shank broaches made from hardened O-1 tool steel. The larger one can make hex's for screws up to M12 and up to 1/2".@bill70j ABSOLUTELY! Thank you!
