Great! I'll count you in!If you have room, I'd like to play, too. I'm pretty good with a lathe, my PM25 mill is OK, but my 4" rotary table isn't the best for profiling.
If I understand the operation of the broach, wobble is going to override the use of circumferential (axial) bearings. The driving unit is rigidly attached to the chuck and the driven unit wobbles in a known pattern to broach the hole. Axial bearing will limit this wobble to the failure of the bearings. Or conversely the driving unit is fixed by the tool post and the driven unit wobbles in the work mounted in the chuck. Or am I missing something?I found some needle-bearings, how do we feel about using some inexpensive needle bearings
The wobble is introduced by the 1 degree angle in the base. The "body" and broach are supposed to remain concentric.If I understand the operation of the broach, wobble is going to override the use of circumferential (axial) bearings. The driving unit is rigidly attached to the chuck and the driven unit wobbles in a known pattern to broach the hole. Axial bearing will limit this wobble to the failure of the bearings. Or conversely the driving unit is fixed by the tool post and the driven unit wobbles in the work mounted in the chuck. Or am I missing something?
I thin that those sets of bearings are turned the wrong way. Don't we need them axial not radial?Great! I'll count you in!
I think we're going to end up doing a decent amount of changes to the design. I think getting us onto an axial and thrust bearing is a good idea. I found some needle-bearings, how do we feel about using some inexpensive needle bearings? Are there any downsides we should be aware of for those?
Next, I like the idea of a 'round flange' instead of the 2 bolt flange on the original design. I suspect that many of us are going to have trouble getting that sort of profiling done accurately enough.
For bearings, does anyone think needle bearings are a bad idea? I found this set (and some others of the same size) that could be pretty cheap: https://www.amazon.com/dp/B082PCTQ2...aWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
I THINK it means the 'broach holder' would have to be pretty accurately manufactured however, right?
Alternatively I see this guy:
Also really inexpensive, but gets our 'body' OD up to almost 2" So, what does everyone think?
I'm leaning toward the 3 piece cheap thrust-bearings were the snap-ring is located on the original drawing (basically, at the back of the holder).
I think we need both axial and radial. We could consider going with a tapered roller bearing to get us both (though, only in 1 direction for axially), but I think they are going to be too large.I thin that those sets of bearings are turned the wrong way. Don't we need them axial not radial?
