The first thing I made on my little lathe was a new hand wheel for the cross slide. I didn't like the factory wheel. I used a piece of 3/4x4 inch flat bar. Turned it round and contoured it, then made a small handle about two inches long and attached it. Fun and simple project and I've got a larger wheel that makes running the cross slide in and out a lot easier.
Meant for use on the saddle drive and tailstock of your mini lathe, this hand wheel is 90 mm in diameter and mounts on a 8mm shaft with a set screw. Get the right mini lathe replacement parts online at LittleMachineShop.
