- Jan 6, 2012
- 113
I bought one of these several weeks ago to deburr parts and to sand the ends on some parts I rough mill a radius on.
![80614.jpg 80614.jpg](https://www.hobby-machinist.com/data/attachments/108/108708-68aacd5825f4bdfbabe4e89bc14427c6.jpg)
It is not perfect by any means but for $69 + tax it wasn't bad.
It needed some tweaking to make it better. It is mostly assembled when the box is opened. I put the table and sanding belt on and plugged it in. The 1st thing I noticed was the lower outer bearing got hot almost immediately, turns out the bearing was in the outer case crooked, about .050" worth and caused some major drag.
![Bearing.jpg Bearing.jpg](https://www.hobby-machinist.com/data/attachments/108/108709-3da43cf01726cf120102a2d0d0da008c.jpg)
I took the bearing case and flipped it upside down and pressed the outer case down flat with the bearing in my press.
Next problem was the fact that both belt rollers were injection molded out of the crappiest reground plastic I have ever seen. and they were so out of round it was pitiful, they were out of round about .050-.060" which caused vibration when the belt was turning.
I put both of them mounted on there respective shafts between centers and trued them up.
Once trued I crowned both of them 1/2° per end by setting the lathe compound and cutting down there length roughly 1.250" per end. This made them track nicely.
The top pulley being crowned.
![Toppulley.jpg Toppulley.jpg](https://www.hobby-machinist.com/data/attachments/108/108710-0d17b462843ac5290b0dead2613ff0dd.jpg)
And here it is finished.
![Toppulleyfinished.jpg Toppulleyfinished.jpg](https://www.hobby-machinist.com/data/attachments/108/108711-604182d6ada018a74e19eb76c49c8748.jpg)
