- Apr 30, 2015
- 11,307
Adds up quick doesn't it?
I USE BRIDGEPORTs AT WORK BUT JUST DON'T HAVE THE SPACE FOR ONE AT HOME .
I BOUGHT A PRECISION MATTHEWS PM-833T TABLE MILL AND MOUNTED IT ON A 33" VIDMAR CABINET .
SO FAR IT HAS BEEN A GOOD MILL AND IS FAR STOUTER THAN SOME PREVIOUS POSTINGS WOULD IMPLY .
THE CABINET STORES THE TOOLING FOR THE MACHINE SO THE WHOLE SETUP HAS A RELATIVELY SMALL FOOTPRINT .
THE MILL HAS NO TROUBLE WITH ENDMILLS AS LARGE AS AN INCH . I USE THEM UP TO 2" BUT ONLY WITH LIGHT CUTS .
IT CAN PUSH AN INCH DRILL AND EVEN LARGE HOLE SAWS IN THE LOWER GEARS .
WILL IT KEEP TIME WITH A KNEE MILL ? IN SOME WAYS YES & IN OTHERS NO .
THE KNEE MILL HAS A RAM THAT CAN BE RUN IN & OUT THE TABLE MILL HAS A MUCH MORE LIMITED WORK ENVELOPE .
THE KNEE MILL ALSO CAN SWIVEL IT's ENTIRE DRIVE MECHANISM AND THE HEAD CAN BE TILTED UP & DOWN .
THE TABLE MILL CAN JUST BE TILTED FROM SIDE TO SIDE .
ANOTHER DIFFERENCE IS YOU CAN SEE A DIFFERENCE IN THE FINISH , THE KNEE MILL BEING BETTER .
I CAN OVERCOME THIS WITH USING THE HIGH SPIRAL END MILLS BUT THEY ARE PRICY BY COMPARISON .
JUST MY 2¢ ON THE TOPIC SINCE I RUN BOTH KINDS EVERY DAY .
I LIKE THEM BOTH AND AM QUITE FOND OF MY TABLE MILL FOR IT's ABILITY TO DO FINE WORK
IN A CONFINED SPACE .
Funny how made in Taiwan is now considered good, and even collectable
If I remember correctly there was a time made in Japan was cheaply made too.
