- Nov 16, 2012
- 5,596
I was going to knock-out some parts today for a pet project and wanted a couple chunks of 4140 to be about Rockwell 38. I got lazy and didn't want to fire-up the electric oven and used a makeshift forging oven and propane.
The heating and quench seemed find. It was tempered by suspending it back in the forging tube and heating with the torch until it hit the 900F needed for that hardness. I used a hand-held IR thermometer but, I must have gotten a bad reading or, the temperature was very uneven inside the tube. Normally, I use an electric oven for tempering because it has a good pyrometer and gives fairly accurate read-outs.
Here's the setup. Quick and dirty and I've used it for lots of simple (unimportant) knock-off parts.
After facing-off the part, you can see exactly what bad heat treating looks like. Look at the area between the 3:00 and 6:00 position on the face of that part; that area is shiny yet, the rest is dull. This is classic uneven tempering. The shiny part is hard and the dull part is not.
Also, I just want to mention that when working with hot-rolled steel, sometimes you get a nice shiny finish once you cut past the scale. If you go a little deeper, most often it starts looking dull again -even if you increase the RPM. This is because the outer surface of the HR steel self-quenched as it cooled and the outer layer is a little harder than the inner core.
Yeah, I know... A lot of folks often give heat treating advice that goes like: Heat it till it's medium cherry red then temper it till its' straw colored...
My father was a T&D maker. My uncle was a metallurgist. Even for simple stuff they used an optical pyrometer.
I'll be doing this over.
Ray
Ray
