- Dec 22, 2015
- 561
To date all my limited experience with turning on the lathe has been with junk yard steel, assumed to be mild steel. I decided that it was time to use some more appropriate steel for making the pins on my Bobcat and got some 4140 and 4340. Today I am turning some 4140 and running into some issues I need guidance with.
It is 1.5" diameter that I am turning down to 1.260". I have the lathe set at 300RPM and using a carbide tool, feed rate of 0.007" with a DOC of 0.015". All starts out fine and the steel is peeling off in tight curls but pretty quickly it starts coming off in larger curls and starts wrapping around the work piece, toolpost, cutter and eventually getting into the chuck. I have to keep stopping the cut to clear this out of the way. I am dripping thread cutting lube on the steel, then spreading it with a brush. I've tried grabbing the steel curl and pulling it away from the cutting tip but it is too hot. It's coming off the cut a bright blue color.
What am I doing wrong and how to I correct this?
