- Dec 17, 2020
- 56
Ok so I need a little help the South bend 9A that followed me home was overhauled not painted (although I should have but no space, I installed a South bend switch and got away from the floppy pole with a switch. I found 1 black wire taped off and the Green wire (Ground or Neutral) coming from the outlet wire, there are 6 black wires coming out of the motor. Also there are multiple wires in the wire nuts some have 3. I just want it wired properly. I wired the barrel switch as it came apart same with outlet plug, I replaced both the 6 conductor wire and the wire to the wall. I used very heavy gauge wire for both (what I could get). I will try to include pics and sorry for the terminology I am no electrician. How is this suppose to be wired correctly? It did run before.
