- Oct 31, 2016
- 2,649
How did you resolve the problem? Just curious. In reviewing your picture and a parts diagram for your lathe (which is different from mine) this is how I would assemble the parts. The lead screw would go through the face plate. Then I would put the washer on. Then I would screw the sleeve/nut onto the lead screw. Don't know how thick your washer is but there appears to be an indent (maybe wrong term) on the head of the sleeve/nut that the washer may fit into. Then the dial which should slip over the sleeve/nut. Next the knurled washer would be screwed onto the sleeve/nut. Then the serrated lock washer. Then the keyed handle and finally the nut. Tightening the final nut would force the handle against the serrated lock washer which would then lock the sleeve/nut in place on the lead screw. Don't know if this is the correct order of parts. Just my best guess.
