Diametral pitch is roughly = (tooth count + 2)/diameter rounded. For example, a 32 tooth gear with an OD of 2.125" would be (32 + 2)/2.125 = 16 pitch.
The two most common PAs are 14.5 and 20 degrees. 20 degrees is the most common, and I believe many of the Bridgeport gears are 20.
Then try Boston Gear to see if they may have a matching gear. You could also read out to H&W Machine to see what they can tell you for your specific machine.
