- Oct 7, 2013
- 149
I hadn’t had this saw long, used to 4 or 5 times now. Wanted a chip/catch tray so this is a cheap & quick way I could see To do it.. These 1/2 sheet alum baking pans are less than $5 and a piece of 1/8” scrap I split since I only had 1. Milled a few small slots for a little adjustment and couple pieces of edge trim for dampening. I think it will work pretty well and only took 30 mins tops. While I was at it I took the gearbox cover off to take a look at the shape of the gears and see if there was any grit in there, but it looked good, gears nice and tight. Seemed like a lot of brass or bronze in the oil, so drained it and added fresh oil..
