- Dec 26, 2016
- 2,019
I haven't tried this myself on a knurled part but on a threaded stock , is to wrap some copper wire around the threads to protect it. (newbie trick)
Not criticism merely a question, often such operations are required when the person that designed the part failed to take into consideration if it may be produced by conventional means as drawn.because I'm a hobbiest not a pro and didnt think the job all the way through or I made a cockup and had to repair it
Yep, that sounds like me except for the drawing part, a few sketches on a bit of scrap paper is my usual modus opperandi.Not criticism merely a question, often such operations are required when the person that designed the part failed to take into consideration if it may be produced by conventional means as drawn.
You have to do what you gotta do in that case.
