Home Made Lathe Omg
H-M experienced a site wide outage on January 23. To the best of our knowledge, the site has been restored up to January 1, 2020. Common problems are going to be missing posts, reverted membership levels and other time related problems that will potentially have been lost between January 1-23.
Please click on this notice to be taken to the Site Support Forum so you can learn more about what happened, what is being done and post a support request so we can help you get your issue resolved.
great white
Jan 25, 2015
590
if it works, it works.
On the plus side, he'll never have to worry about getting parts for it!
The drill press he was using was also interesting....I'm guessing a walk through his shop would be interesting.....
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
4,612
Molten metal + sandals + shorts = disaster waiting to happen.:chemist:
tomh
Jan 14, 2013
290
ROLMAO yeah I saw that to and thought He will catch hell for that.
MY dad had a small foundry just under a city block size so NO you wont catch me doing that LOL
But isn't it amazing what some folks see in a pile of scrap.
But on the other hand some folks love flirting with disaster, you know here hold my beer bob:devil:The drill press he was using was also interesting....I'm guessing a walk through his shop would be interesting.....:encourage:
ogberi
Oct 20, 2014
494
Aside from the cringe worthy safety issues, that's excellent work. I didn't see any precision measuring equipment in evidence, so I do wonder if he takes the "cut, try to fit, cut, try to fit" route. Most of the machines look homemade, and at the very least, usable. And a usable tool lets you refine your tools. I'm surprised he hasn't built the "engine block universal machine" yet. I would. Uses engine blocks as the bed and column/headstock. The bores of the cylinders on the headstock/column are used for the spindle. It can be used as a lathe (imagine getting another 5-6" of swing by simply moving your spindle to a higher bore!), a horizontal milling machine, and with some structural tubing bolted to the column to hold a spindle, a vertical mill.
Kudos to him for making usable machines out of scrap. Makes you wander out to your shop, see all the mass-produced stuff, and say, 'Wow. I got it easy!'
tomh
Jan 14, 2013
290
The lathe must work pretty good as he uses it to make parts for his tractor, which is down rite amazing to say the least!!
like you I would love to see his shop in action and it appears that he is Fairley young also.
hman
H-M Platinum Supporter
Feb 17, 2013
2,481
It demonstrates the difference between the accuracy actually needed to make something work, and the accuracy some people think is needed to make anything work!
I'm reminded of what I've heard was a motto of the Russian arms industry (possibly originated during WW2) - perfect is the enemy of good enough.
Especially liked the way this guy made use of scrap-yard parts like old motorcycle and other(?) transmissions. Wonder how he got the lathe bed rods and the cross slide rods parallel???
hermetic
May 2, 2011
580
he will have put the saddle on to the bed rods (motorcyclr fork legs
he will have put the saddle on to the bed tubes (motorcycle fork legs) and then fixed them at either end, so that the bushings on the saddle held them parralell . I built a little machine for my brothers leather business which cut a v notch in e piece of leather to fold box corners, and used two round bars for it to slide on. I did it the same way. I will try to get a pic of it and post it up.
hermetic
May 2, 2011
580
This is the device I meant uses the same two long parallel bars. You slide the handle along and it "skives" a 90 deg slot in the surface of a piece of leather which is then filled with glue and a corner formed. used for making cases. Unfortunately he seems to have neglected it a little!
Phil
easttex
Nov 28, 2015
25
I went to his YouTube channel this morning it looks like he's in Ukraine. I'm sure he's lacking access to proper tools and education and making do as best he can. I've got to hand it to him for being this creative though. Just imagine what he could do if he access to real equipment and a solid training course on how to run them!
Sent from my SAMSUNG-SM-G900A using Tapatalk
hermetic
May 2, 2011
580
Well I know where you are coming from, but how many people do you know, who, having had access to real equipment and training, would go on to make their own equipment without the use or availability of a lathe! I think sometimes the burning desire to do something overcomes all obstacles and achieves that end, whereas the training would tend to convince the trainee that it couldn't be done accurately enough to be usefull, which is obviously wrong!
Phil
ebgb68
Sep 1, 2014
229
Thanks for sharing .
hman
Feb 17, 2013
2,481
What we have in this video is almost a demonstration of the old adage that the lathe is the only tool that can be used to reproduce all its own parts. Thanks again, tomh, for posting it!
63redtudor
Oct 25, 2014
33
Having been to several 3rd world countries its actually impressive at what people with nothing can make. Deffinately not the safest way to do things however! Unfortunately what I have seen (also in 3rd world countries) is the way people can come up with way to kill each other. :chagrin:
I see similar things with older, depression-era made tools. Much of my lathe tooling was made by my grandfather who grew up in that era. I also have a power-hacksaw from that era and while it can (and eventually I hope to) be improved, it works and thats the main thing. At the begining of most of my 'how to run a lathe' books there's a comment that's basically along the lines of - "work holding and/or tooling has more to do with the skill and imagination of the operator..."
Downunder Bob
Staff member
May 16, 2016
1,314
He might lack access to sophisticated tools, but i suspect he has had some formal training, possibly in the military, He obviously knows how to go about what he needs to do, and is familiar with how machines work.. Nonetheless a most amazing achievement with much made from little.
I take my hat off to him, a true achiever.
dlane
Sep 27, 2014
3,073
I'm impressed,
Home made mill, surface grinder, lathe's
Bet there's more,
I'm guessing he started off welding and the fabrication continued .
Downunder Bob
Staff member
May 16, 2016
1,314
Noticed the person also used the shopmade lathe to “climb mill”!
That shop made lathe / mill must be pretty tight the way he is climb milling on it , no sign of chatter or grabbing.
FOMOGO
Sep 2, 2013
2,112
Pretty inspiring video, thanks for posting Tom. Also what makes us the most dangerous animal on the planet, and as noted above we are awfully good at using it against each other. Just imagine what an amazing world we could have if we all worked together toward common goals. Kinda like this forum, but on a much grander scale. Well, I 'm going to hold onto that thought, and continue to ignore the "news". Cheers, Mike
wildo
Dec 7, 2015
512
This video series reminds me of a book series (that I don't own- it's in my amazon wish list!) called "Build Your Own Metalworking Shop From Scrap" by David Gingery. https://www.amazon.com/dp/1878087355/
Some of you might already have it. Some of you might enjoy it if you don't have it already. And some of you might wish for it (like I do) and put it on a list somewhere...
12bolts
Global Moderator
Apr 23, 2011
2,476
I saw some plastic calipers when he was making his aluminium donut in the 1st. And some steel verniers in the 4th. Interestingly he improved on the tool post design on his smaller lathe
Cheers Phil
Tim9
Oct 11, 2015
442
Found this by accident while surfing utube. If you watch all 6 parts you will be amazed what some people will see in a pile of scrap and what their imagination can do, as they don't see problems they see solutions.
safety Nazis beware!
https://www.youtube.com/watch?v=E-As4...
I sa that guys videos and watched all of them a while back. He's a skilled craftsman. Makes one realize how good we have things in the USA. In some parts of the world... Finding a used lathe requires a father-in law who is a high ranking Politburo Official.
cathead
CATWERKS LTD
Feb 7, 2013
1,208
I watched the casting video and the lathe assembly video and was impressed with his dogged perseverance to build a lathe
out of what he had at hand. I wouldn't be too quick to judge him by his apparel.
