Hi,
I made these covers up for my lathe to stop the chips getting on the ways and the lead screw, I wasn't sure if they were a good idea because they might get in the way.
After being on for about 2 1/2 years they have worked great, the only modification has been to cut the one on the saddle back 20mm to allow it to come a little closer to the head stock.
The saddle one is attached with 2 top screws that attach the standard way wiper's so no extra holes. I bent up and mig welded the 2 sheet metal plates together, it about 0.5mm thick.Under the ends of the cover that might touch the ways I glued some rubber inner tube to stop the steel touching on the ways if pushed down.
The lead screw cover is attached with 2 screws into the gap bed. The 2 holes were there already for the US style carriage that has the rack on the gap. They were puttied/bogged over. It is made up of 2 sheet metal plates 0.5mm thick welded together.
The tray underneath the chuck just sits there in between the ways and makes it easy to empty the chips into the garbage. It also stops the hassle of trying to get the chips from around the gap bolts and out of the socket head bolts that bolt it down.
Clean up time on the lathe ways have been cut by around 75%.-90% on jobs near the chuck.
Dave
Dave
