- Mar 15, 2019
- 708
I made myself a work bench or more correctly a work bench frame, I haven't settled on a top just yet. It is 6 feet long and I was thinking a built up top of some hardwood I have in the garage. So I went out to the garage and saw the countertop I removed from the kitchen during renovation. There are 2 pieces one of which has the cutout for the sink, which reminded me I also had a double basin stainless sink in the rafters. The countertop would be a less than ideal work surface but honestly I have used worse, but that 2 basin sink is almost begging to be put to use as a parts washer which I have been wanting for a while.
Help me with some ideas to make this work. I have the sink and a pump from a fountain and assorted plumbing for the drains. I am thinking about just draining to a 5 gallon bucket with a lid taking the drain pipe to the bottom and a divider in the middle to allow time for the swarf to settle out before spilling over the top to the part where the pump is. Should do OK protecting the pump from all but the smallest bits of metal.
What do you think?
What do you think?
