- Nov 25, 2015
- 8,332
Everything is a problem in California.. Air can cause cancer in California... At least that's what the warning label when you get off the plane says.well, sodium hydroxide is drain cleaner so that should give a clue,
Sodium Nitrate is used as a preservative in bacon and hot dogs. Its also found in a lot of plant products especially spinich so again should not be a problem.
Mind you from what I gather it may be a different problem altogether in California.
