- Feb 8, 2014
- 492
Finding a new pulley is out of the question, I found 1 that might work and it was $1300.00.
I got some time this morning to work on it again and I cleaned the crank shaft and remeasured it, it runs true and the diameter is 1.375 +0 - .002
I laid the pulley on a flat surface and the rim is as true as my flat surface, Cast table saw top.
There was a lot of crud in the pulley hole so I cleaned it out good and remounted it on the compressor and the wobble went from .490" down to .150".
It fits nice and tight when it's clamped down but has a little play when the clamp bolt is loose, I'm thinking I will see if I can shim it to get it a little better unless that's a bad idea. I may just live with the .150".
ALSO, NEED INTAKE AIR FILTER
