- Dec 26, 2016
- 2,019
Thank you RJ, the grind on the bit you posted looks like the trepanning cutter I found picture of online. wasn't sure it would cut the 1/4" thin plywood efficiently ( thought it might dig into the plywood too much) so I passed on it , I could grind one end of the bit that way to compare with the one Mike mentioned.
Thanks for your suggestion and the pics.
