I just purchased a 5 HP compressor pump from Amazon. It seems (seemed?) like a nice pump, but it has some real issues. One of the top ones is the silly elbow fitting they sent with the pump to provide the outlet air. For one, thing, it is far too short to properly clear the pump housing. given that, and its other issues, I will just be discarding it. The next issue is the female port is not SAE: it is metric. I don't know if anyone has tried to get a schedule 80 or equivalent metric pipe and elbow, but I haven't seen anything of the sort. The biggest issue, however, is the female threads in the pump housing (and the elbow, but that no longer matters) aren't pipe threads! They are not tapered. They are perfectly flat. They appear to be m27 x 1.2mm threads. I can make such an external thread on my lathe easily enough in order to mate with the pump housing, but how am I supposed to seal them if they are not tapered? The outlet temperature is reported to be very high - high enough for lead/tin solder to fail if used to solder pipes together at the outlet. That would eliminate epoxy. Even though neither the elbow which came with the pump nor the pump body have tapered threads, I suppose I could still taper the threads on the adapter I am going to make, but I am not sure how well that would work. For one thing, it might well still leak, even though the fitting is tight and sealed with PTFE. Worse, it could fail completely, and a 1" pipe coming off a 200 PSI air port... well, I don't want to be anywhere in the same building, that is for certain. So how should I get a presumably non-tapered, threaded air connection to seal properly?
