I recently cut my first test gears (https://www.hobby-machinist.com/threads/my-first-gear-cutting-adventure.78446 ) and now I'm thinking if I had to make a gear to mesh with an existing gear how would I go about finding the correct PA? For example my 9x20 Grizzly lathe's change gears seems to be DP25 which I'm thinking is actually Module 1, I figured this out by using the formula DP=N+2/OD. Now I can find M1 gear cutters but they come in different PAs, 20 seems to be more common. How do I find the PA of an existing gear?
Also, has anyone made their own single point gear cutter by forming the correct profile so you don't have to buy expensive gear cutters for any oddball size that you run into?
