- Feb 2, 2013
- 3,677
you can take the measurements for output at the plug, you'll have little chance of hurting yourself.
you'll notice one leg on the plug looks different,
it will either be bent inward [leg in,30amp] or bent outward[leg out, 20 amp] that is your ground leg.
you won't use it for testing at this point.
start up the unit, test across 2 hot poles of the plug and record your reading.
move 1 lead to the other hot pole you have not tested and record your reading.
move the other meter leg back to the first pole to get the last reading and record.
that will give you all three phase to phase voltages .
at this point ,you could also put one lead to the ground pole and test ground to phase for each pole as well and record your readings.
i hope i didn't confuse you more, if i did LMK, i might be able to explain differently
