- Mar 30, 2014
- 115
Bought a benchtop drill press for some small projects. Nothing major or super critical, but I would like for it to be true if I can without spending a lot of money.
It's a brand new harbor freight 8in. Got it on clearance for $74.
The chuck was not installed, so before I installed it, I checked the runout of the spindle and was quite surprised it was only about half a thousandth out.
I install the chuck and then chuck up a drill bit. I check just above the flutes and I have about 4.5 to 5 thousandths runout. So it appears the runout is in the chuck and not the spindle/shaft.
So is this a acceptable amount of runout for a drill press? I do not know what drill presses usually run (runout wise) and what is normal and what is not.
Should I try to get a different chuck? Would another chuck even be any better?
