- Apr 23, 2013
- 1,013
As and old school machinist I have never checked if my qctp repeats to a thousand or a tenth. Sixty years ago when I ran turrets I trusted that when I indexed the 4 way tool post that it would repeat. Also I always backed off the dia about .010 thousands because nothing is perfect and took a test cut when I changed inserts. More because I worried a spec of dirt or something got in the insert pocket.
I also remember using a tenth indicator and watching a tool jump a tenth or so when the lathe motor switch was turned on or off. Most jobs who cares.
I think it is a bit silly to worry in a home shop when most jobs are one offs.
I also backed off the tool dia when I ran CNC lathes When I changed inserts.
Another rant is when a new guy trying to learn how to grind tools goes to a book showing how it was done over 80 years ago. I have never seen a modern shop using those tool shapes in a modern shop. And some people try to make relief angles to some exact angle. I NEVER check angles when I grind tools andI never have.
And why 118 degrees for a drill point? Why not 120 degrees?
Rant over.
jimsehr
Rant over.
jimsehr
