[4]
How to determine a drill size for a thread.
[3]
[10] Like what you see?
Brento
Active Member
May 9, 2018
133
I need to tap a 1.035-40 thread in a square piece of aluminum. Is there a formula to figure out the prebore size
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
922
The simple method.
Major Diameter - the lead. This will get you in the ball park.
In this case 1.035 - .025 = 1.010
P. Waller
Mar 10, 2018
922
Guhrings calculator does not calculate the thread dimensions just brings up a list of standard ANSI threads.
The 1.039-40 thread is not listed in the standards and appears to be proprietary to an optics manufacturer, it is likely that this company is not keen on publishing the thread data.
Brento
Active Member
May 9, 2018
133
Thats what i used as well to get a size. Funny thing is the thor labs is what the part is for lol
P. Waller
Mar 10, 2018
922
Exactly, I used the easy method and it yielded a minor diameter of 1.010 for a 75% thread fit, well within Thor's recommended sizes.
I have not used a tap drill chart in years, I just subtract the lead from the major diameter, this works for all 60° V threads.
P. Waller
Mar 10, 2018
922
I am not a "Web Machinist" but I ignore the tenths unless it is a grinding operation (-:
pstemari
H-M Supporter - Gold Member
May 18, 2015
413
For a UN thread, the v-height is (√3/2)÷TPI, the actual thread height is 5/8 of the v-height, and the nominal minor diameter is the major diameter - twice the thread height. That simplifies to:
Major diameter - 0.625×√3÷TPI
or
Major diameter - 1.0825÷TPI
which is just a tiny schooch smaller than the Md-1/TPI mentioned above. The factor of (√3/2) is just 1/2 of the tangent of 60°, which is the thread angle.
That gives you 100% of a UN thread form, which is pretty close to the "75%" thread you'll see referred to, which is 75% of the obsolete American National thread form. IIRC the American National thread form was replaced by the Unified National thread form during WWII.
The American National thread form had a thread height of 3/4 the v-height, and called for internal threads that were slightly sharper than UN threads. Compared to American National threads, UN threads have slightly blunter internal threads and UN external threads don't have to be as deep.
One other factor is the allowance for class 2A/B threads and tolerances for both class 2 & 3 A/B threads. That calculator from the Theoretical Machinist web site is the only one I'm aware of that provides a calculator for the tolerances and gives you actual minimum and maximum values for minor, pitch, and major diameters.
Sent from my Pixel XL using Tapatalk
[6]
[5] [7]
