How to Determine Motor Speed?
ShagDog
Jun 11, 2020
318
I have the motor show in the attachment on a South Bend 9 with flat belt drive cone pulleys. For Rpm, the motor is labeled "1725/1140". I did a calculation on the current set-up based on 1725 Rpm which if my calculations are correct(?) I come up with the slowest spindle speed of about 415 rpm. The countershaft drive pulley has 2 steps, and it is on the smaller step. The motor drive pulley is 3" diameter.
If the motor is running at 1140 rpm, I think I would come up with a spindle rpm of about 274, again, if my calculations are correct (?).
How do I tell if the motor is set up to run at 1725 or 1140 rpm; and if at 1725, how would I reduce it to 1140 rpm? Also, would there be any issue in running it at 1140?
Does the nameplate have a wiring diagram? I doubt that you would want to run it on the lower speed. At any rate, you should be able to get info on wiring it from Grainger.
I used a similar motor to increase the capability of my Hercus 9”ARH.
Here is a photo of the way it is wired. No wiring diagram found.
Edited.
So it really is a two speed motor then? Must be two ways of connecting it
I think so
Looks like the power would connect to the center stud and one of the others for hi or lo
Green really should be reserved for ground though, not used as a power wire
Doesn't look like you can reverse that one
