- Dec 18, 2019
- 6,528
From the title, you can tell I'm having issues with accurately and precisely measuring the diameter of a turned rod. I'm trying to measure and correct the headstock alignment of my lathe. Annoyingly, it seems it is easier for me to measure the diameter by the chuck than further towards the tailstock. For some reason, the tailstock side measurements seem to be (for lack of a better description) bimodal. The readings are clustered around two different values, maybe 0.0005" apart.
Now I know that most of the answer is practice. This morning I made so many measurements that my hand was cramping. But it didn't seem I was making much progress. I have had one consistent run of 10 measurements with a standard deviation of 0.00023". The measurement set of 10 I made previous to it had a standard deviation of 0.002!
Can anyone share some tips and wisdom how to get the right feel to know whether one is truly on diameter? I try to lightly rock the mic to see if I'm really on diameter, but it always seems that my consistent measurements are a little tight on pull away. I'm concerned that the 'good' measurements are consistent but not necessarily accurate. It would seem this is a fundamental skill to master.
It's kind of frustrating to think you have it right, lock the mike and bring it back to the part and find out it is quite (0.001") loose, or on the other hand feel like you might be slightly flattening the part.
Measuring off lathe doesn't seem to be a problem for me. Just on lathe. If a kind soul could offer some insight, I'd greatly appreciate it.
