Hi All, can any of the experts among you give me a hand with something?
I am working on a 3D printer that I have built up, the bed that things are built on is made from aluminum plate with a heater built in under it, the plate is about 210 x 210mm and 3mm thick.
For the printer this bed needs to be a flat as possible and it is mounted in the machine with bolts at each corner, the bolts attach through springs which allow one to level the bed by adjusting the mounting bolts.
Problem is that being thin aluminum the bed has been manufactured with a bow in it leading up from each corner toward the centre.
I mounted it flat on my milling table and took a light surface cut with a 50mm index face mill but I was not thinking and all I achieved doing this was to flatten it with the clamps, face mill it and then reintroduce the bow when the clamps were removed (I think it is even worse now).
I am looking at ideas on how to now flatten it more correctly.
What I have come up with so far is the following:
Taking two sturdy pieces of aluminum bars longer than the plate I tapped holes in each bar and mounted the plate to this bar using its mounting holes. The bars in turn were clamped to the milling table. This now in mind has the plate secured to the table but still allows it to keep it's natural bow.
I then plan on face milling it again like this (very lite cut, almost like a lathe spring cut), which I am hoping with make the top flat even though the bottom may be slightly bowed (when in use it does not get much pressure on it, only light plastic parts are built on it).
I started this tonight but the chatter was terrible and amplifier so much by the plate that I decided to try again tomorrow as making such a racket at midnight is very neighbor unfriendly.
In the mean time maybe some of you may have a better idea on how to go about this?
Thanks
Anthony
Thanks
Anthony
