- Feb 28, 2019
- 499
I've got some ideas on how to handle what happened tonight, but looking for other advice on how to handle and control drill wandering.
What I did
Drilling a #14 hole (just under 3/16) thru a 1" thick piece of hot rolled steel (this is practice, actual part will be 1018 or stainless). Following with a a 3/16" reamer. First hole actually came out great, straight / parallel to two reference sides, checked with a dowel pin and a surface plate. The hole was slightly off position (the point of the practice is dial in precise location as compared to mating part / hole).
Adjusted the position slightly by .004 and checked again and the fit with the mating part was off by almost double? lots of head scratching and finally realized I could measure the entry and exit hole from the reference surface on a surface plate.
The exit hole was off by about .004 - .005 so my adjustment was practically double! Made sense once I figured out the hole was not parallel to the face.
Drill process was to spot with a centering drill (that's what I got) and then just drill through. everything locked except the quill. The #14 drill I have is full length and of questionable origin. However it seemed sharp and drilled fine. The entry was right where I wanted it.
I did have to take the part out of the setup check, adjust and try again. It's possible that I got sloppy with the second setup. I'm using the fixed vice jaw against the reference face as my way to ensure the hole will be square to that face. The part is tall 1" and narrow .3 thick.
I've ordered drill screw / short bits and will try again tomorrow paying more attention to the setup. I think the short bits will help, but it seems odd to me that I could have gotten the face not flat against the vice jaw the second time. could be a bit of swarf but I cleaned everything pretty good.
Like I said the entry was in the right place.
How do you drill straight true holes 3/16 x 1" deep? Again, not looking for advice on accurately locating, that part worked fine.
Thanks in advance.
What I did
Thanks in advance.
