- Nov 28, 2013
- 197
I've included photos of what I'm trying to do. The device shown is an adaptor for my Chinese 6040 Router to enable it to cut foamboard parts to make r/c planes quickly. It clamps on to the router spindle and uses the reciprocating .025 wire to cut the board - very much like a sewing machine. I call the part which has the stand-off-nut modified to grab the wire the rotor. It is 3d printed PETG.
There is an M3 bolt which is supported by two 6mm ball bearings inside the rotor. This thing will be running at 8,000 rpm. Getting a good press fit on the bearings on a 3d printed part was easy. I used the Goldilocks method - make three, vary the bore dimension slightly and one of them is sure to be just right. And one was just right.
I haven't cut anything with this yet, but I expect that the PETG rotor may not last long due to the pounding and would be more durable if I made it from 6061. Getting a good fit for the bearings might be important. I thought it would be useful to see how good a fit I could get in a waste piece of aluminum. I bought a 6MM end mill, drilled a slightly smaller hole in the aluminum and then using my Sherline, ran the mill down the axis of the newly drilled hole and got a very nice looking bore. But he ball bearing is a wee bit loose. This might not be that important because the two bearings one on the front and one on the rear of the rotor are held in place by being squeezed between the head of the bolt on the back and the wire inside the stand-off nut on the front. It runs very smoothly at 8k rpm, to my surprise.
I'm guessing that I should use a 6mm reamer to get a closer fit. I'm also thinking of using blue threadlocker to secure the bearings.
What would you do?
What would you do?
