I've acquired a Delta brand model 62-185, Marathon manufactured single phase motor I want to use on my just built belt grinder. It is 2 HP, 10A, 230V, C-face motor. May have originally been on a Delta DC33 Planer. My knowledge of electric motors is limited but in searching information, I've come to believe this is a capacitor start-run motor. It has a 30 uF as well as a 230-276 uF capacitors on it. I assume the larger one is the start capacitor disconnected by a internal centrifugal switch at the appropriate speed. This motor spins counter-clockwise and I need to reverse the rotation. I hope to not have to dismantle/remove the end bell of the motor. Can reverse be achieved by simply switching start capacitor terminal wires (colored red and yellow, a black wire connects both capacitors)? If not, I could use some advise on how to go about it? The power switch/fuse box has a blue and red wire to it from the motor. Your thoughts on this would be greatly appreciated. Thanks.
