- Jul 13, 2014
- 1,051
What Marcel says actually does work for very small adjustment and wont hurt the chuck cause you ain't smacking it with a 5 pound sledge. You give it a sharp heavy tap. I agree with his method , as i have done that on occasion.
Now on to your question.:
I chuck up a 1" ground bar a few inches long ( a piece of drill rod or turn a 1" bar). I loosen the bolts holding my chuck to the back-plate. (my chuck has three dowel pins in the back-plate locating it. I think the register is bad. God only knows what this thing has been through all these years.) I get my chucked up rod indicated within as close to perfect as possible. 1 or 2 tenths at least. I then tighten the bolts and reamed and re-pinned my back-plate and chuck. Because of parts fit, wear and manufacture accuracy The chuck will generally repeat within a few tenths AT THAT DIAMETER ONLY. Because of the factors I just mentioned, when you chuck up at any other diameter there is going to be error. How much error depends on the condition , wear , and quality of your chuck. I was fortunate that this Union chuck was a very good chuck and the worst run-out I get is .0025", but if I chuck at 1" diameter, I can get it to a few tenths run-out on a turned bar.
Take note: To get the repeat-ability I have to sometimes chuck,and un-chuck a few times, and at any other diameter, I do the same till it gets as close as possible to true. If I just throw a piece in the chuck and tighten it, It may be out .002" to .003". Also you can only get accuracy on a piece that is true round. If you throw a piece of CRS or HRS steel rod in the chuck , you cant expect any accuracy till you turn it. I hope I explained this so it is easy to understand.hew:
Mark,
Thank you.
It makes sense the way you laid it out, I think I can follow the procedure. Got an Asian 3J I can try this on. It has 0.006 run out on the 1 inch test bar I picked up from PTG.
