- Apr 12, 2013
- 562
It appears to be a broken off scope mount screw with a off center drilled hole in a failed attempt to remove it. This is in an older Remington model 700 ADL.
My plan is to finish the existing hole to see if it relieves the screw enough to get the remnants out with an ez out or even pick it...pry it away from the original hole.
Failing that I was considering trying to figure out the milling attachment for my lathe and see if I can plunge a 1/8" endcutting mill down the original hole, and then follow it with a #28 drill bit in preparation for retapping to 8-40 thread.
My goal is obviously to not have the new hole for the #8 screw follow the off center current hole.
Any suggestions and advice are welcomed before I mess it up worse.
