- Feb 28, 2019
- 501
mill a sawtooth profile with only a mill and a a lathe?
The dimensions don't really matter that much (I'm interested in the technique) but for talking purposes, consider a piece of metal 1" high, 6" long and maybe 1/4 think. The goal is to cut a sawtooth like profile on the top, in crude ascii art:
_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_/|_
|________________________________|
In reality, the teeth and angle would be flatter, with or without flats between the teeth.
Same question for cutting a gear rack. The catch is that you only have a lathe and a vertical mill.
I can see only two approaches, try to set my lathe up as a poor-mans horizontal mill or make a D-Bit with the right profile and use the vertical mill.
I'm not thrilled about using the lathe as I'd be controlling the pitch with my carriage or limited by the the travel of the cross slide on my compound (or both).
In the vertical, I'd need to make a D-Bit to cut a rack and then mill away half of each tooth to get a sawtooth profile.
Interested in other possible approaches (tell me I need to purchase a horizontal mill!!)
-Dave B
-Dave B
