- Sep 7, 2012
- 64
Inexperienced newbie question alert:
I'm working on a "Boring and Transfer Block" from Metal Lathe in Pa. http://www.statecollegecentral.com/metallathe/U-12.html
The suggestion is to turn the 4-jaw chuck into a fly cutter to rough things out and reduce the casting to where it will just fit the 9" ENCO lathe I've got.
The 1/4" HSS tool ground to a Vee will make about three passes over the face of the cast iron block and then dulls to the point (or lack thereof) where is just skates over the CI. I reground it with the same result. Then I ground the surface of the CI block off with an angle grinder to get through the skin that I've read about. Remounted block on crossfeed and tried again, same result. Grind new cutter just in case I ruined the temper in the other one. Same result.
Running the lathe fairly slow. Slowest speed in regular gearing. Tried it fast once and that was really dumb! See, I can learn.
Bad HSS bit? Buy and 1/4" shank replaceable carbide bit set and shorten one shank so I don't have too much tool sticking out?
Ideas please.
Thanks, Dale (the 56 year old new guy that wants to learn machining.)
Ideas please.
