- Sep 8, 2013
- 120
stupoty.... To tell you the truth, I think they are. I bought them at an estate sale where the owner had a lathe. I bought all the lathe bits for $5.00. It's possible that they are not, but I cannot even run a file on them. I'm going to run to MSC and pick a few up and probably order some more from ENCO because the same bits are about half the price. The carbide just doesn't seem like it's the way to go at this time due to the cost and my inexperience.
pineyfolks... Sorry if I'm asking juvenile questions. I really want to get into this and have to crawl before walking.
- - - Updated - - -
That's where I get confused. There are so many variables with the turning tools and the compound. All of them swing around 360 degrees.
- - - Updated - - -
If the second pick shows the machine as you were using it, your cutting on the back corner of the tool. The bevel at the end of the cut sort of confirms that.
Swing the cutter about 45 degrees so the leading edge is cutting and the end of the tool has slight clearance to the right.
Greg
