Hi guys,
Ive got a HY GT series VFD which is rated for 11kW and I am driving a 3 phase inverter from a 3 phase source.
Ive noticed that after reading the manual and setting up the VFD that I can use the autotune parameters provided some motor details are provided. But I have inserted everything the VFD should need to run.
The motor is a Perske motor rated at 10A @ 380V 3ph. its speed is 17500-21000 rpm and our line frequency is 50Hz here in Ireland.
When I go to autotune the motor I get a "tE" which according to the manual is a trip error.
I can run the motor using the start/stop button but it doesn't run the motor but the RPMs increase without the motor turning.
Anyone have any experience or advice with these units.
Thank you
Thank you
