- Feb 16, 2014
- 26
I know this is an inexpensive VFD, and my problem is minor, but here it is.
I was able to succesfully program the 3 HP HY VFD that is running a 2 HP motor on my Harrison L5. The programing is not too different from my 3 HP Motortronics running a grinder, but I have used the HY manual to the best of my ability to follow it.
I have forward and reverse working on a remote switch, and the remote speed control is functioning. I have the lower and upper speeds functioning but I cannot enable the Estop or the reset function.
The forward function is accomplished with a switch closure, as is the reverse function. I was able to use the old control switch after rewiring it into a SPDT center off switch, and that part is fine.
It's not that I can't live without the estop, but it would make the buttons that I mounted more useful.
From the diagram that I used to successfully wire the Forward-Reverse controls one would assume that a simple switch closure would engage the estop function, as holding the contact closed causes forward operation until the switch contact is opened. Bringing the Estop control lead to ground does nothing.I would have thought that the Estop would be engaged by grounding that contact. Not so much.
If anyone has any insight on this it would be appreciated.
As I said, the lathe functions right now, and if I never get the estop and after that the reset to operate I can still use the lathe, but It would be nice...
paul
paul
