- Jun 20, 2022
- 215
I've had my lathe for almost a year. Apparently I don't learn. I did a very light boring job in AL on a face plate tonight. When I went to clean the machine the faceplate was hopelessly stuck.
This is not the first....or second....or third time I've stuck my chuck. Each time it has been from failure to inspect the threads for swarf and there being a few very tiny pieces (AL I think) in the threads.
The last time this happened I made a tool. A rod with left hand threads on one end that goes through the spindle. Except that didn't work. The rod kept spinning in the spindle bore despite being REALLY tight. So I got out the torch. Heated the faceplate pretty damn hot. And I got out a 1lb ball peen hammer, and bolted a nice chunk of steel to the faceplate to pound on. The shock of whacking it did the job (eventually) despite the rod wanting to rotate. I was starting to envision cutting the faceplate off the lathe and wondering how I'd do that without screwing the spindle up.
My lathe and everything else appear to have survived unscathed. But since I'm too dumb to remember my penance is admitting I'm stupid for not cleaning the
%$%ing threads every time I change out the chuck. Hopefully this reminder will help one of you to not be as stupid as I am. Clean and oil your spindle and chuck threads before you install it.
I wonder if anyone makes 3D printed chuck thread inserts to keep swarf out while they are sitting around? Or maybe I should buy a nice 1 1/2" piece of delrin and make one.
